arhayes's avatar
arhayes
Repairs in Minneapolis?
Any recommendations on a reliable place to get my TH's axle bearings packed and brakes adjusted, and get a check done on the LP system to make sure it's adjusted correctly. We'll be staying on the western side of the city. In a couple of weeks. Thanks
  • Will do. I was very impressed with their responsiveness when I called. I was going to have them look at alignment plus check and adjust brakes. Now I need someone to do an annual on my LP system. ??
  • I just had my coach in to Precision Frame. They found enough variation in the camber and alignment that would have cost me tires in the short term.
    I will be going back next year to upgrade to an independent suspension with disc brakes. They do great work!
  • While you're there you might want to have them check your wheel alignment. That's what they do and they're good at it. I won't go anywhere else.
    B.O.
  • Appointment made with Precision for the 29th! Pleadureland will be close so if they can get me in we'll give them a try. Thanks, all!!!!!
  • Precision Frame and Alignment in Elk River, MN. can take care of the brakes and wheel bearings for you. There isn't a better place in the Country to work on your suspension or brakes. Check out their reviews.
    B.O.
  • Other options:
    Pleasureland in Ramsey northwest of Minneapolis
    Brambillas in Shakopee southwest of Minneapolis
    I have used both and while neither was a standout they did OK.
    Noble RV in Jordan also has a mobile service. They are southwest of Minneapolis.
    This time of year it may be tough to get it done right away.
  • I use Mikes' RV service, but they are more east side of town (1350 Frost Avenue)651 770-9448. My parents have used Hilltop Trailer and been happy with them (closer to the west side of town). 7810 University Avenue, Fridley 763 280-7446
    Steve
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,131 PostsLatest Activity: May 12, 2025
