Txsurfer
Jun 22, 2017Explorer
Running a portable Gen in my built-in Gen space
My TH has a compartment for a built-in (on-board) generator that is empty. It has a louvered door. I have a Champion 3100 that will fit in that space with room to spare. I have an aftermarket exhaust extension kit. I also have a long-run tank mod done that allows it to run off a 6 gal boat tank. I am thinking that if I leave the door open and the exhaust is directed out the bottom of the compartment ( I can bend it to then turn out to the side if need be) I should be able to run it it without removing it. My main concern would be carbon monoxide but my exhaust mod should take care of that correct? The unit is fan cooled like most of the inverter type units so I believe that as long as there is enough room in front and back of the unit I should be OK. This would keep it out of the weather and require less lifting on my part. What do you think.
