โJul-20-2021 07:39 PM
โJul-26-2021 06:03 PM
Gdetrailer wrote:enblethen wrote:
I would not jump out and do anything until the shore power cord is identified whether it is two or three wire! If it is two wire you are asking for problems!
However, I did have a 1981 TT . That panel most definitely had all neutrals and grounds connected via a single ground/neutral buss bar..
So, in reality it is possible to find RVs with 30A shore cord but yet neutral and ground connected together.
โJul-26-2021 04:57 PM
Bud
USAF Retired
Pace Arrow
โJul-26-2021 04:29 PM
โJul-26-2021 02:28 PM
Bud
USAF Retired
Pace Arrow
โJul-26-2021 01:41 PM
โJul-26-2021 01:39 PM
โJul-26-2021 01:31 PM
โJul-26-2021 01:17 PM
Bud
USAF Retired
Pace Arrow
โJul-26-2021 01:02 PM
time2roll wrote:mr_andyj wrote:Yes the neutral bus and ground bus in an RV should be separated. RV panel is a sub-panel.
It is plugged in now so dont want to take it apart just yet, but best I remember is it did look factory, not just wires going in odd places, the neutral looked like it was factory made to be grounded where it was, but I cant say for sure that it was not just grounded to the ground bar.
Nonetheless, would it be wise to unground it? That would mean the neutral is only connected to the neutral of the extension cord, not the ground of the panel that connects to the ground of the extension cord.
I can do electrical just fine, but am not an electrician that knows the codes.
Neutral-ground bond should only be made at the main power source panel supplied by the utility transformer.
โJul-26-2021 12:32 PM
โJul-26-2021 12:29 PM
Bud
USAF Retired
Pace Arrow
โJul-26-2021 12:04 PM
โJul-26-2021 11:36 AM
mr_andyj wrote:
I have a panel out of a 1971 camper.
The neutral is grounded at the panel. The neutral is grounded, as many are saying yet others somehow want to disagree with such facts...
What some here are saying is that this code has changed and now the neutral is not supposed to be grounded at the panel?
Should the neutral be un-grounded and let the neutral ground effect take place at the house panel, not the caper panel? Would this help eliminate some possible issues with reverse hot skin?
โJul-26-2021 09:43 AM
Bud
USAF Retired
Pace Arrow
โJul-26-2021 09:24 AM
