rebardwa's avatar
rebardwa
RV window seal
I recently removed three windows from y 2006 Fleetwood Southwind to clean the clouded windows. Upon removal of te windows I discovered I had a rubber type seal instead of butyl putty seals. I have gone to several RV dealers and none of them have ever seen or know of any seal material other than the putty tape. If Nyone has see this type of rubber seal before and know where I can order it I would appreciate any guidance.
  • I'm in the process of fixing the windows in our MH, Bounder. They have a rubber seal but I was as careful as I could be not to destroy it. I did put a few tears in them but I'm pretty sure they'll be okay. Once installed the outside is clamped pretty tight against the side of the MH. The top edge also has silicone sealer. I searched online and couldn't find seal like the ones on our windows.
  • Hard to match your seal without a picture or a description. I've used different butyl seal tapes and there are a few available at my local hardware store.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,130 PostsLatest Activity: May 09, 2025
