elliotthere's avatar
elliotthere
Sagging rear springs when towing.
Trailer max GVW 10,000lbs Hensley WDH.I want to install Hellwig helper springs 1000 lb rating, Is this the right rating.
Thanks for any advice Dave
  • I had to add air bags to my EX to overcome the soccer mom springs Ford put in, and I have been very happy with the results. Thought about a spring swap (X code I think) but didn't want any lift/height added to it. Seems to barely fit in a lot of the parking garages in the area with only an inch or 2 to spare.
    Adam
  • My understanding is the rear springs are fairly soft on the Excursion, and these exact ones are now 13 years old. I'd talk to a suspension shop about just replacing them with some that have a little higher spring rate.
  • OP's setup per profile
    Ford 2004 Excursion Eddie Bauer 6.0L
    3.73 rear axle
    137 in wheel base
    Hensley Arrow hitch
    Prodigy trailer brake
    Starcraft/Homestead 29SKS
  • Give Helwig a 1-800. They can give you what actually works. We can only guess what works.
  • The rear of our F250 settles 1.5" with the hitch properly adjusted. This is normal. How much sag are you seeing?
  • What do you mean by sagging exactly? 1 inch? 5 inches? What is your tongue weight? Is the hitch adjusted correctly?
    Some sag is normal. Even with the hitch adjusted you will still have a couple of inches of sag.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
