dspencer's avatar
dspencer
Screen in the emergency exit window
I have a 2013 Gray Wolf 26BH. The screen came out of the emergency exit window and I can't get it back in to save my sole. Can anyone help me with this?
  • Need pictures to assist.
    Each of my window screens are all pressure fit with clips on the inside of the screen.
  • Mine work like Don's. That being said, I removed and did not reinstall. Figure that The last thing I would want if the exit had to be removed is ripping the screen off.
  • MY windows have a plastic channel on the bottom that I have to pull out first before I can remove the screen. Check and see if there is a plastic channel on yours.
  • Thank you DSDP Don, i will work on it today and see if I can get it in. I was afraid to push it very hard.
  • "dspencer".....There are several styles. Some have a small set of triangle spring bars on one side to keep the tension. On those, you install the spring side first, pushing down and then insert the opposite end.
    Another type uses a larger opening than the frame where you often insert the screen into the upper slot as far as you can and then force the bottom in over the lower slot.
    No matter which one you have, most require you to insert one end in the slot and then push the rest of it in.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,106 PostsLatest Activity: Jan 26, 2025
