mtnbbud's avatar
mtnbbud
Feb 12, 2023
Should I paint galvanized vent caps?
I'm replacing my plastic pipe vent caps with galvanized metal caps. Should I paint them before or put the on, or with the galvanization be enough?
If I do paint them, does anyone have recommendations for which paint to use and prep work. There's a small bolt and nut on the top of these. I'm thinking cover these with some Dicor?
  • One or two coats Rust-oleum or Hummerite paint. Big issue is to neutralize the galvanizing using cheap white vinegar. Use stainless screws for mounting.
  • Thanks all for your input. I believe the original plastic covers made it 30+ years, but I figure I might as well be sure and paint them if there's a chance they will eventually rust. There's a Sherman Williams paint store near my house. They should know what primer and paint I should use. I might even bring along the caps when I ask them. Better to play it safe than to have to replace them in the future...
  • Community Alumni's avatar
    Community Alumni
    I worked at a hardware store and if I remember there is a primer or paint made for Galvanized metal
    JimR
  • I would suggest painting with a good quality paint. Make sure to wipe down with vinegar to get good adhesion. The thin metal of your cap is most likely electro-galvanized and not hot dipped. Electro-galvanizing doesn't last!
  • So many paints won't stick. Do what tinners do... wipe galvanized metal with vinegar to etch it. Craig
  • The only reason to paint them is if you want to have them match the pipe or other rooftop parts.
  • Galvanized steel will last for 10+ years without rusting. Do remember the old metal galvanized steel garbage cans?
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,130 PostsLatest Activity: May 09, 2025
