Brownleaf's avatar
Brownleaf
simulator hub cap lug nut covers
I have 04 class c minnie winnie land need to get some more of the chrome acorn like lug nut covers. While I see alot advertised on the web I think mine are 9/16ths on 22.5 tires. Does anyone else have this exact model and can both confirm the size and where to get more? Thanks Doug in Durham.
  • Brownleaf wrote:
    Tires are LT225/75R16 so what size is that tire?
    The LT 225 indicates that it's a light tuck tire with a tread that is 225 millimeters wide
    The 75 is the aspect ratio - meaning the sidewall is 75% of the width
    of the tire.
    R stands for radial and the 16 is the height - 16 inches.
    So you have 16 inch wheels.
    Lug/Jam Nuts
  • That is a 16in wheel---what part of Durham are you in?, I may be able to help you out.
  • I’ll go out on a limb and say there is zero chance a Minnie is on 22.5s unless you made it into a donk….
    And maybe a 0.01% chance it’s even on 19.5s.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,110 PostsLatest Activity: Feb 16, 2025
