GaryS1953's avatar
GaryS1953
May 08, 2023
Solar Panel Mounts
Hi All - So my new (to me) camper has Diflex 2 roof. Could I put those drill free plastic mounts on this kind of roof, and should I? I'd rather not put holes in the roof if I can avoid it. What is the consensus on those glue on mounts? Do they hold up well?
https://www.amazon.com/Spartan-Power-Drill-Trailers-Skoolies/dp/B0B43VGFQZ/ref=sr_1_11?crid=24IIFRUYY96GR&keywords=solar%2Bpanel%2Bmounts%2Bfor%2Brv%2Broof&qid=1683585001&sprefix=Solar%2BPanel%2Bmounts%2B%2Caps%2C122&sr=8-11&th=1
Thanks!
  • Shortening Amazon links . . .
    This:
    Becomes:
    All the **** after .../B0B43VGFQZ/ gets cut
    Becomes:
    Clickable Link
  • Interesting idea. I don't like the fact that they are hollow on the bottom giving a small surface area for adhesive though.
    On a positive they look like a not previously thought of good candidate for my 3d printer.
  • Personally, I would never rely just on those, especially on a rv roof. people have put them down with two-sided tape, but I say just screw in. make sure your on studs, squirt roof sealant into the holes before you drive the screw in then use a self-leveling sealant over top and it won't be an issue
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,130 PostsLatest Activity: May 11, 2025
