Welder99 wrote:
Hello,
Anyone on this site have a Solo Fire pit? Looking into getting one. What size did you buy. Pro’s and Con’s …Thanks in advance. P.S did u buy any accessories, if so what did you get.
My observations (ignoring the price difference)
If you really want something that will mimize any smoke, the solo is great. If you want very close to the same control of smoke but also want lots of heat, a washing machine drum is better.
Either is orders of magnitude better than typical campground fire pits for control of smoke, amount of heat, ash, and amount of wood needed.
And with a screen on top IMHO (and several rangers who have seen our washing machine drum with SS grid on top) much better for fire danger from sparks, embers, etc.
A top load washing machine drum radiates a great deal of heat and doesn't smoke if you keep the wood below the top. The solo has a inner and outer drum with air going in the bottom up then exiting at the top. like a washing machine drum it keeps smoke down with a blast of hot air at the top, but the inner/outer drum makes a heat insulator so it doesn't radiate as much heat as a washing machine drum.
And a washing machine drum is way less expensive. The best ones are the comercial stainless steel drums, very light weight, I welded on some large (3/4") nuts on the bottom (3) and have some long bolts I can attach to raise the drum off the ground. Or if we are in a place with a firepit I just set it on top of a firepit grate.
The washing machine drum like the solo burns most everything down to a fine ash.
