teddodd's avatar
teddodd
storage allegro
can anyone provide any suggestions on how to get the three
compartment doors up high enough to get access to store my items?
this is on the drivers side on a 2011 allegro open road 32'.
they also come out with the slide. cannot get tiffin to explain this setup. thanks,
  • I would call Tiffin for an answer. The doors on the DS open easilly to provide access and they are mounted on the slide.
  • Piano hinged doors usually swing almost 180 degrees to be latched in the up position. Sometimes you have to pull outward ever so slighty as you move through the 70-100 degree position.
    But yours may be different, though it doesn't make sense that they would have been designed not to open fully.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,120 PostsLatest Activity: Apr 01, 2025
