way2roll
Apr 19, 2021Navigator II
Dutch_12078 wrote:
If this is the ReadyStop system from NSA, the only way I can see it locking up the brakes without being pulled on from the front breakaway loop would be if the ReadyBrute/ReadyBrake applied the brakes and somehow the ReadyStop cable became jammed where it passes through the firewall. The ReadyStop cable is not in a casing like the ReadyBrake cable and there should be at least 3"-4" of slack in it between the brake peddle and the locking device. The slack should be wire tied where it can't be snagged by any moving parts of the vehicle.
It is the ready brake system. That's what's weird, when I disconnected and pulled the cable through the firewall there was no resistance. I didn't try both ways though. But like I said, the red unit, was totally frozen. The release button wouldn't work. I do recall it getting worse as I applied the brakes, so I guess it's totally possible that applying the brakes pushed the cable through the unit and it wouldn't come back. But there is no conduit the cable slides in to enable this to happen easily - pushing a chain up a hill comes to mind. The main cable has such a sleeve. I would still consider that a failure on the part. I see the new ones have a grease zerk, mine does not. Very possible it simply rusted and froze up after these years and we live near the shore where salt air accelerates corrosion.
No one was hurt, thank goodness and a few minute fix. If I ever tow it again I'll just have to reinstall a new one.
Just very weird it happened out of the blue and behaved like a breakaway.
Is it possible someone pulled the cable - like a kid or something while we were parked somewhere? Doesn't explain why the release wouldn't work though. And doesn't explain why it didn't do it while leaving our neighborhood until we got out on the main road. I will probably never know the root cause. Thank goodness I figured out what happened. Initially I thought it was a seized caliper and was ready to call a tow truck.
On edit: Something else that was odd, the main supplemental brake cable was apparently pulled also, so hard in fact that it snapped the cable at the brake pedal. Must have taken some serious force to do that.
DW tells me sort of casually that parking the other day she scraped the bottom of the front spoiler on a curb. Lightbulb! I guess it's possible this caught both cables and pulled them taught. Still doesn't explain why the breakaway decided to wait to some random time a day later to engage and not let go, but it does add a piece to the puzzle and probably explains the snapped primary cable.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,116 PostsLatest Activity: Mar 08, 2025
