T.v. storage ideas
prolandsurveyor
I am wanting to keep my tv on the dinette table while in motion does anybody else do the same....and how can I keep it from moving while traveling?
2013 Thor majestic 28a
1971 vw superbeetle
13 REPLIES 13
CavemanCharlie
I have a lift off wall mount for my TV. I lift mine off and lay it face down on the foam rubber dinette cushion that is nearest to it. I have heard that laying it down on it's face is suppose to be bad for it but, I have been doing it for years with no problems.
Ron3rd
jerryjay11 wrote:
I use to throw mine on my bed so it is cushioned.
X2, used to do that too. New trailer has a different setup
Equilizer Hitch
Honda EU2000
DutchmenSport
Both televisions, on the bed, even though they both have wall mounts. I have quick disconnects.
77rollalong
Was thinking of mounting a flat screen in the center section of the front upper bunk with a long enough arm to swing forward to be viewed from the dining area/ sofa
mat60
Thanks OP for asking. On the bed it is.
2018 Heartland Trailrunner 24 SLE... 1999 old style Chevy 2500 with 34k
mobeewan
Tv on the bed and surrounded with pillows.
D_E_Bishop
Both of ours are mounted on swing out mounting brackets like many rigs have them. Haven't had a problem, I just tightened up the pivot bolts so they stay in place.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
2009 GMC Canyon
Roadmaster 5000
BrakeBuddy Classic II
Cocky_Camper
Both of ours goes in the middle of the bed, and it has never budge while in motion.
2004 Sea Breeze by National RV - 8341
Former Coaches:
2006 Keystone Zeppeline 291 - TT
2000 Aerolite Cub F21 - Hybrid TT
1991 Coleman Pop Up
Formerly known as: hybrid_camper
Sam_Spade
Not a wise thing to do, I think.
If it is not attached to a wall, then having it on the floor is a better place for it to ride.
But then, bungee cords can do wonders, regardless of where you put it. Might have to mount some attachment points on wall, floor or table though.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
navegator
X-3
On the bed next to the wall and the blanket on top.
navegator
the_bear_II
X2 Bed
Or You can use a ratchet strap to secure it to the table and get some of the non-skid material to put under the TV
maddog348
XX2
jerryjay11
