โMay-11-2021 10:33 AM
โMay-14-2021 06:20 AM
โMay-14-2021 06:19 AM
mkirsch wrote:Mike134 wrote:
If you properly load the trailer you won't need sway control because a "PROPERLY" loaded trailer won't sway.
What's "proper?" Do you have a formula, or a method? Every trailer is different. Some will not even wiggle with 5% tongue weight. Some will whip all over the road with 20%.
"Move stuff around until the trailer stops swaying" doesn't seem like a very practical way to go about it.
โMay-14-2021 05:49 AM
โMay-13-2021 05:21 PM
Mike134 wrote:loydt wrote:
Just bought a new Jayco White Hawk 32BH. It has a GVWR of 9995 Lbs and a dry hitch weight of 1,100 Lbs. My truck is a 2018 Ram CC 4x4 dually with the Cummins/Aisin combo and a factory class V hitch. Do I need to mess with a WD hitch for this massive truck?
I don't think folks read word questions very well here based on the responses.
You have a 1-ton dually that has a payload in the neighborhood of 5500lbs. Was factory equipped with a class on V hitch. Those can have a 18,000- 20,000 rating. You have the extra heavy duty transmission for that diesel. I'd bet if you dropped 1800 lbs of tongue weight on that beast of a truck your front wheel well height might go up 1/4". If you properly load the trailer you won't need sway control because a "PROPERLY" loaded trailer won't sway.
Just my 2 cents based on the information you provided.
โMay-13-2021 05:04 PM
โMay-12-2021 08:24 AM
You have a 1-ton dually that has a payload in the neighborhood of 5500lbs. Was factory equipped with a class V hitch. Those can have a 18,000- 20,000 rating. You have the extra heavy duty transmission for that diesel. I'd bet if you dropped 1800 lbs of tongue weight on that beast of a truck your front wheel well height might go up 1/4". If you properly load the trailer you won't need sway control because a "PROPERLY" loaded trailer won't sway.
โMay-12-2021 07:53 AM
โMay-12-2021 06:02 AM
โMay-12-2021 03:52 AM
loydt wrote:
... So far I have only found one hitch system, made by Curt, that has a tongue weight rating of 1500 lbs.
โMay-12-2021 02:51 AM
โMay-11-2021 09:07 PM
โMay-11-2021 06:36 PM
BarneyS wrote:Mike134 wrote:
I have to chuckle at the weight police. I've been on the forum a few years and all you read is you need a bigger truck, blah, blah, blah. The OP has a 1-TON DUALLY ONLY towing a 10,000 trailer and suddenly it's not enough truck?
You guys crack me up.
Safe travels, hitch up and never look back at the forum.
Who said he needed a bigger truck? I noticed a lot of questions about the receiver on the truck but not the "blah, blah, blah" that you talk about.:R
Barney
โMay-11-2021 06:24 PM
loydt wrote:
Sorry for the delay. I can tell you that it's a class V hitch with a tougue weight rating of 1800 lbs per ram website. The truck itself has a maximum trailer tow rating of over 30k pounds.
โMay-11-2021 06:23 PM
thomasmnile wrote:
Wonder what the Ram owner's manual recommends. Haven't seen a vehicle manual that doesn't address towing if it's capable of towing.
