โNov-10-2019 04:03 PM
โDec-16-2019 11:01 AM
โDec-15-2019 03:40 AM
โDec-09-2019 05:42 PM
olfarmer wrote:
You need to figure out where the leak is. It could be the floor seal or it could be the fresh water supply or the flush valve. I guess if you can't get to it and can afford it, just replace the unit, but, make sure you have a new floor seal gasket to put under the new stool.
โDec-08-2019 07:37 PM
โDec-08-2019 06:53 PM
โNov-11-2019 11:59 AM
rexmitchell wrote:
I may just buy a new one since I don't know what is wrong and can't look at it before going out there. Seems I can get the same model online for around $150 shipped. If I pull it off replacing it should be easy. Any tips for replacing it? Do I need to purchase any other parts? It says it comes with needed harware/seals to connect to existing water lines and floor flange.
โNov-11-2019 10:18 AM
โNov-11-2019 08:56 AM
โNov-11-2019 08:21 AM
โNov-10-2019 09:59 PM
โNov-10-2019 07:19 PM
โNov-10-2019 07:12 PM
โNov-10-2019 06:19 PM
