dernst
Sep 01, 2016Explorer
Tongue weight & equalizer
I am buying a Ultra Lite 2702ws which has a tongue weight of 800 pounds. My dealer says that an equalizer will be able to reduce the tongue weight in half. Does this seem correct?
RinconVTR wrote:drsteve wrote:the WDH will transfer/redistribute to the TT axles which is typically in the 15% to 25% of the dead tongue wt.Incorrect--TW has no bearing. It could be 1000 lb, or it could be zero. The amount transferred depends solely on the spring bars. Your TW scale, btw, would show an increased load on the hitch ball, rather than a reduced load.
Read the entire sticky. It's all there.
Yes, it is all there, but you are not understanding what is being said. Bareny explained it a bit, as have others.
Consider if you have zero tongue weight...no weight is being applied...thus nothing is distributed. Zero = Zero.
Where you are getting crossed up is "tongue weight" and the load actually being applied to the hitch or vehicles rear axle with the WDH connected.
Point also being made about payload and capacity is that the WDH does transfer some weight off the vehicle entirely, the amount that is transferred to the trailer.
In my experience, I have seen as little as 100lbs move the to the trailer and as much as 300lbs, with trailer tongue weights between 500 and 1000lbs.
Should you use this transfer of weight in your calculations? That's up to the driver. But realize the scale is all that matters, as long as you use it and retain the document (printed weight results). It is in fact, a legal document.
So if the scale says you are within all specified capacities (Axle weights, Gross Vehicle weight, and Gross Combined Weight)...you have proof in print that you are legit.
That payload sticker on your door jam is meaningless once you hit the scale, as its derived from the numbers you measure on a scale.
BarneyS wrote:
You two are arguing semantics. Ron, in his post, tries to distinguish between the terms "Tongue Weight" and "load". The reason for this is that many people (especially the new ones), because they have heard that a trailers tongue weight should be between 10 and 15% of the total trailer weight, think that that WD hitch will take some of that tongue weight away and make the trailer more sway prone. He put that in there to prevent that type of thinking. As he says, the "tongue weight" does not change. Just the "load" resulting from that tongue weight is re-distributed.
Please, lets not get into a "pissen match" over this. :)
Barney
It is interesting to note that TT weight and “tongue weight” do not enter into these calculations. The WD hitch does not distribute “tongue weight”. It simply removes load from the TV’s rear axle and distributes it to the TV’s front axle and the TT’s axles.
drsteve wrote:Larry JM wrote:
drsteve wrote:
The tongue weight is still the same, it's still on the hitch, and must still be counted against the cargo capacity of the TV.
While the first half of you statement is true the second half is WRONG. The dead (i.e. what would be measured by something like a Sherline TW scale) tongue weight will not change the amount of that TW that will be "cargo" on the TV will be that dead TW minus what the WDH will transfer/redistribute to the TT axles which is typically in the 15% to 25% of the dead tongue wt.
Larry
Sorry, but that is incorrect--tongue weight doesn't enter into the equation. Read the sticky on WD hitch setup by Ron Gratz. Tongue weight could be zero, and the hitch would still redistribute the same amount of weight.
A weight distribution system enables a tow vehicle to more effectively handle the tongue weight of a trailer by removing some of the load from the tow vehicle's rear axle and distributing it to the tow vehicle's front axle and the trailer's axle(s)[unquote].
That load on the rear axle w/o the WDH engaged includes the tongue wt and the total wt. on the two axles of the Tow Vehicle equals it's wt. w/o the trailer attached plus the tongue wt. When the WDH is engaged that wt. will be less by the amount that the WDH redistributes to the TT axles (i.e. reducing the "ORIGINAL LOAD" ... i.e. tongue wt that was originally cargo against the TV cargo capacity).
Larry
Larry
