Hello trying to figure out what the tongue weight is on my set up. I have a 6x12 Utility Trailer weighting around 900lbs and the golf cart is 1300lbs. So what would the tongue weight be around? Thanks
Assume 15% of the loaded trailer and you will not be far off. So probably 330. Rule of thumb is 10-15%, seldom far off. A single axle trailer with the weight forward might push 20%. Double axles tend toward the 10% unless badly loaded.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,104 PostsLatest Activity: Jan 22, 2025
