โMay-14-2021 08:49 AM
โMay-18-2021 10:39 AM
โMay-18-2021 10:27 AM
โMay-18-2021 08:29 AM
โMay-18-2021 07:34 AM
ajriding wrote:
Sorry, Biscu2ski, I dont follow, info missing. You keep mentioning sag like it is magic and going to throw weight all over and make it go away. I dont know how this is relevant, do you?
The point of bags is to keep vehicle level, so talking about how sag will minutely alter weights slightly is not relevant. Bagged trucks ride level! WDH trucks generally ride level, so we are talking about level.
Put in your formula a 900 lbs motor way at the front of a long truck and see how much hitch weight it takes to lift that motor alone, not to mention other components. I think you will see quick we are talking NOT about front end weight, but, rather, hitch weight and weight limits of the components of the tow vehicle, which is usually wheels/tires.
The only number that seems to matter is what the truck can carry (payload) at the rear.
โMay-18-2021 06:38 AM
blt2ski wrote:
Yes the pivot point is rear axle.
As I noted, if you can keep the rear end high vs level vs tail down, the amount of weight removed from the fa will be less vs more as a percentage of hitch weight added....
Marty
โMay-17-2021 10:48 AM
โMay-16-2021 04:42 PM
โMay-16-2021 12:12 PM
โMay-16-2021 10:25 AM
โMay-16-2021 09:05 AM
โMay-16-2021 05:54 AM
ajriding wrote:
I finally weighed.
Someone said something about having no WD hitch and the rear axle as a fulcrum unweighting the front axle, so I did math. I weighed my small trailer only so far.
I weighed about 350 lbs tongue weight. Not a lot.
Anyone else run similar numbers?
โMay-15-2021 09:14 AM
โMay-15-2021 09:11 AM
โMay-14-2021 06:14 PM
