Horizon170
Oct 16, 2018Explorer
STBRetired wrote:oldschoolhdmike wrote:
my issue is the ratchets. I cannot release mine because they hit the bumper of the car. I physically have to unbolt them from my master to dolly.
If you look closely at the ratchet mechanism, you will see that there is a plate that gets pushed back when you move the handle to the release position. If you cannot open the handle that far because it contacts the bottom of the car, you can use a short pry bar to push back the plate and release the ratchet strap. Much simpler that unbolting the ratchet mechanism.
My solution was to place a 2" X 10" under each tire. I still don't like the one size fits all straps.
Marvin
BTW, I have one chain strap almost completed using tire chains.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,117 PostsLatest Activity: May 14, 2021
