jerem0621's avatar
jerem0621
Apr 21, 2015
Tow-N-See Towing Mirrors
just got my towing mirrors for the Chrysler Town and Country. I haven't seen these mentioned here very much and wanted to show this as an option for people out there. Maybe do a longer term review as they age too.
here they are installed from the front.
These mirrors use fancy suction cups to mount directly to the TV's mirrors... I know.. I know... Suction Cups?????
Yes, but they are a little more than just that.
These give the user an advantage that no other add on Tow Mirrors can give... the ability to adjust the tow mirrors from inside the TV by using the power mirrors in the TV.
There is a drivers side and a passenger side... The drivers side is a flat mirror while the passenger side is convex.
Here are a few more pics, a little closer up
There is a knob on the end of the mount that you turn to create a very strong vacuum that holds the mirror very securely.
Sounds crazy but there is little to no vibration in the mirror at towing speeds, there is a safety strap just in case the mirror falls off.
The instructions are pretty clear, clean the mirror, clean the suction cup.. install, tighten the knob down.
Here is a picture of the convex mirror..
Why did I choose these?
These mirrors are the only option that do not clamp onto the body of the mirror or on the door of the TV. They are the only aftermarket tow mirror that is somewhat adjustable on the fly.
Anyway.. I don't have a lot of miles on them right now, but plan to put thousands on this summer with the PUP.. we will see how they hold up and if any issues arise.. I may try to update this thread from time to time as they wear in and if any issues pop up.
Thanks!
Jeremiah
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 23, 2026
