Billinwoodland's avatar
Feb 20, 2015
tow plate/tow bar interchangeable between manufacturers?
I'm shopping for used tow bar and base plate for a Vitara. I may end up having to buy the base plate new. How interchangeable are the tow bars and base plates between manufacturers?
Thanks
Bill
  • enblethen wrote:
    Roadmaster are very easy to install on a Vitara. A little more work on the Grand Vitara depending on year.
    Go to Roadmasterinc.com and download instructions for your year and model.
    Thanks Bud, and thank you for your service!
  • Roadmaster are very easy to install on a Vitara. A little more work on the Grand Vitara depending on year.
  • I think it depends on the auto being installed on.Go on the base plate mfg and download the instructions.I like blue ox they look cleaner when not towing.The big difference, blue ox and demco have the cross bar behind the grill road master has crossbar in front of car.
  • Thanks Dutch. Does anyone have an opinion (lol) on any particular brand of base plate that is easier to install, or are they all about the same in terms of the knuckle scraping index?
  • There are usually adapters available if the base plate and tow bar don't match up. One exception is NSA's ReadyBrute tow bars, where the arm ends can be changed to ones that mate with a given brand/model of base plate.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,111 PostsLatest Activity: Feb 18, 2025
