- Wilson123ExplorerMowermech. That's exactly the process I read when I googled it. It's almost like you wrote that google answer.
jocat54. No, BMW said that only if I had the front wheels on the dolley and the car in neutral. - jocat54Explorer
Wilson123 wrote:
Yes. 2 wheels on the ground. The more I think about it I may disconnect the drive shaft and tow it front forward. I think once I get it up on the dolley I can get under it.
I can't quite understand why a rear wheel drive car with the rear wheels on a tow dolly would have to started and driven to lubricate anything.
The only thing turning would be the front wheels bearings. But if the manufacturer says so--I guess that's the way to do it. - mowermechExplorerI had a Datsun pickup many years ago that I had to do that with. It only took a couple minutes to slide under there, take the four bolts out of the rear driveshaft yoke, wrap the u-joint with black electrical tape to keep the bearing caps in place, tie the shaft to a cross brace on the bottom of the bed with a piece of wire, and bag the bolts and clamps in a zip-lock bag. The bag went in the glove compartment.
It didn't take long to put it back, either.
Yes, it CAN be done, IF you are willing to do it. - Wilson123ExplorerYes. 2 wheels on the ground. The more I think about it I may disconnect the drive shaft and tow it front forward. I think once I get it up on the dolley I can get under it.
- wbwoodExplorer
Wilson123 wrote:
My dolley wheels turn. BMW said I could put it in neutral and tow it normally but every few hundred miles I would not only have to start it but drive it to lubricate everything properly.
Are you sure that is for a tow dolly and not flat towing (4 wheels on the ground)? - Wilson123ExplorerBoy, that what if had some stories. I still have 3 weeks to make a decision so I am in no rush yet. Maybe pulling the drive shaft isn't going to be very difficult.
- mowermechExplorer
Bobbo wrote:
There is a big difference between "it has been done" and "it is a good idea." Towing a rear wheel drive vehicle backwards has been done, successfully, but it is not a good idea. If it causes problems, e.g. the steering wheel lock breaks, the wheels turn, and the car swerves sideways and hits something, you will be liable.
Well, if we are going to play "WHAT IF"...
What if the left front wheel of your car comes off and goes across the street into the 7-11 parking lot? It actually happened to me, in high school, but the wheel didn't hit anybody.
What it both left rear wheels come off your rig at 50 MPH, and roll down the highway? That happened to the school bus I was in once. The wheels didn't hit anybody.
What if the receiver breaks away from the frame of your motorhome and leaves your toad sitting in the middle of the road? That was reported on these forums a couple years ago.
What if the whole front end of your toad breaks away, leaving the car in the middle of the road and the bumper attached to the motorhome?
That was also reported here, with pictures.
What if an airplane lands on the back of your car? That happened many years ago. The car was a 1959 Chevy.
What if some fool drops a bowling ball off a freeway overpass, and it lands in the middle of your windshield? That happened years ago, too.
What if your trailer breaks away, runs across the median, hits a car, and kills someone? That happened right here in Billings a few years ago!
Yes, "WHAT IF" can be carried to ridiculous extremes. But remember, EVERY ONE of the things mentioned REALLY HAPPENED!
If one is going to worry excessively about WHAT IF, perhaps one should just stay home. BUT WAIT! Consider all the accidents that occur at home. It is not safe there, either!
Oh, what to do... - Wilson123ExplorerI was going to put a couple of small ratchet straps on the steering wheel to each door handle so it couldn't move regardless if the steering lock broke.
- jayleona7900Explorerpulled a 2007 mustang backwards for 3 years averaged about 8000 miles
a year no problems. - BobboExplorer IIThere is a big difference between "it has been done" and "it is a good idea." Towing a rear wheel drive vehicle backwards has been done, successfully, but it is not a good idea. If it causes problems, e.g. the steering wheel lock breaks, the wheels turn, and the car swerves sideways and hits something, you will be liable.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,111 PostsLatest Activity: Feb 18, 2025
