Van1938Tuscany's avatar
May 18, 2017
towing 2015 Honda Fit
I tow a 2015 Honda Fit manual transmission. The owners manual requires me to pull 3 fuses to save the battery, 1 is in a box under the hood (easy for this seventy year old too do), the other 2 are in a fuse box under the dash. This box is not easy to access.
Does any one have a solution for pulling the other 2 fuses?
  • Instead of pulling fuses to keep the battery from going dead, run a charge line to the Fit battery from your motorhome. Dick
  • Pull the fuse and put a spade connector on one side with a piece of wire coming out of it. Take that to an inline fuse connector. Take that to a switch on the dash. Take the other side of the switch to a spade connector and plug that into the other side where the original fuse went.
    Take the other fuse to the same switch.
    Done. :)
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,110 PostsLatest Activity: Feb 15, 2025
