Rperksp's avatar
Rperksp
Towing Capacity
Newbie to Fifth wheel towing. We just purchased a 2015 2500 Tradesman, 5.7 Liter V-8 Hemi, Crew cab, 6.4 bed, with an axle ratio of 3.73. The manufacturer of the truck indidates the tow rating for this vehicle is 11,200 lbs. However, in taking into consideration passengers, payload, and weight of fifth wheel hitch, this is reduced to 9,542 LBS. The Fifth wheel we are looking at is a Cougar 27RKS, Shipping weight of 7136, Carrying capacity of 2864, Hitch weight of 1230. It will generally just be the wife and I that will be traveling, so fully loaded trailer probably won't be much over 8,000 lbs.
Does this sound as if the truck will be able to tow this trailer safely with a 15-20% differential added in as a safety margin?
Also, the salesperson at the trailer location said you could add 15% to the towing capacity with a fifth wheel set up compared to a trailer. Not sure if the salesman is just blowing smoke here.
Thoughts?
Rob.
Specs for 27RKS
Shipping Weight 7136
Carrying Capacity 2864
Hitch 1230
Length 30' 5"
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 17, 2025
