scolson's avatar
scolson
Towing capacity
I'm looking to purchase either a 5th wheeler or travel trailer and I'm not sure what the towing capacity is of my truck. Here are the specs for my truck. Thanks.
Vehicle Name Ford F-150
Body Style Crew Cab
Drivetrain Four Wheel Drive
Gross Axle Wt Rating - Front 3900 lbs
Gross Axle Wt Rating - Rear 3850 lbs
Curb Weight - Front 3214 lbs
Curb Weight - Rear 2372 lbs
Gross Vehicle Weight Rating Cap 7350 lbs
Gross Combined Wt Rating 13500 lbs
Dead Weight Hitch - Max Trailer Wt. 7700 lbs
Dead Weight Hitch - Max Tongue Wt. 770 lbs
Wt Distributing Hitch - Max Trailer Wt. 7700 lbs
Wt Distributing Hitch - Max Tongue Wt. 1155 lbs
Fifth Wheel Hitch - Max Trailer Wt. 7700 lbs
Maximum Trailering Capacity 7700 lbs
Engine Type Regular Unleaded V-8
Displacement 5.0 L/302
Trans Type 6
Trans Description Cont. Automatic w/OD
Spring Capacity - Front 3900 lbs
Spring Capacity - Rear 3850 lbs
Axle Type - Front Independent
Axle Type - Rear Rigid Axle
Axle Capacity - Front 4050 lbs
Axle Capacity - Rear 4100 lbs
Axle Ratio 3.55
Front Tire Capacity 4050 lbs
Rear Tire Capacity 4050 lbs
Wheelbase 145 in
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,106 PostsLatest Activity: Jan 27, 2025
