Towing difference?
Bobj616
I would like to know if anyone can tell me if there would be much difference in towing an 8000 lb trailer or a 7000 lb trailer . My truck is a 2013 f250 gasser and I have the equalizer weight distribution hitch. there is less than a foot difference in length.
2015 Arctic Fox 25Y
2013 F250 6.2
10 REPLIES 10
TUCQUALA
Went from a 27ft 7100# trailer to a 34ft 9200# trailer, and feel that it tows just as well, if not better!! Feels more steady, extra weight doesn't seem to have loaded down the Ex even on high (8000') passes!!
'16 Outdoors Timber Ridge 280RKS
Reese 1700# Trunnion w/ DualCam HP
'03 EXCURSION XLT V10 4.30 Axles
Artum_Snowbird
Bobj616 wrote:
Thanks folks. Snowbird ,I am not using the truck in my signature. I have an F250 with the 3.73 and camper package now , it shouldn't be overloaded. but thanks for replying.
Geez, I should have seen that. You will hardly notice the difference for most driving. High mountain passes cut the power for gas engines, so it will be noticeable there most likely. My 1 ton 7.3 works pretty hard dragging 9300 in the fifth wheel, sometimes second gear up hills. Once even first gear, but that is the steepest highway in BC.
Mike
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers,
Triple E Motorhome and Fifth Wheel
Bobj616
2015 Arctic Fox 25Y
2013 F250 6.2
Artum_Snowbird
It's not quite that easy. What you are talking about can be over the towing limit, or just under. You are loaded to the max, and without knowing what it is you really have in mind, the towing is not going to be fun.
If you are talking a fully loaded trailer, versus an empty one, you have to really see if you can put the combined weight together, with the heavy hitch, and whatever you take with you in the truck and the trailer.
Check the charts yourself, learn about your read end ratio, your wheelbase, 4 by 4 or regular.
It won't be fun, that much is for sure. Going to feel like a heavy load.
Mike
lbrjet
You can add close to a 1000 lbs just by running with full tanks on a lot of trailers. I doubt you would notice much more than a very small difference.
2010 F250 4X4 5.4L 3.73 LS
2011 Flagstaff 831FKBSS
Equalizer E4 1200/12000
BB_TX
Unlikely you would notice much difference unless there were significant aerodynamic differences or weight distribution differences.
Triker33
Depends on what you are going to haul in the trailer.
A F250 can pull 12,500 lb with the 3.31 or 3.55 and 15,000 lb with the 3.73
Either with the 6.2L or 6.7L engine.
1,000 lb difference may make a .1 loss or less in MPG
Larry Full Time Since 99
1999 34Q Discovery DP ISB 275HP 6 Speed Allison
VMSpc | Pressure Pro
14 Lincoln MKS EcoBoost Toad
Click here to see where I am
brirene
All other things being equal, I doubt you'll notice any difference.
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
โ€œCertainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
Bobj616
There is always one in the crowd. lol .
2015 Arctic Fox 25Y
2013 F250 6.2
WNYBob
About 1,000 lbs!
