cinandtim's avatar
cinandtim
towing on 5ooo lb hitch.
Have a 2012 Jayco Greyhawk motor home and pull 2008 Jeep Liberty all wheels down. Jeep has curb weight of 4269lbs. Greyhawk has 5000lb hitch. Don't even know the jeep is back there. My question is thinking about upgrading to a Jeep Grand Cherokee, 6cl is 4545lbs, 8cyl is 5150lbs. Would really like to go with 8cyl. PRACTICALLY am I ok at 5150lbs curb wt on 8cyl?
    In all probability, the hitch itself won't be an issue if it passes a structural inspection by yourself or someone else. Will you be exceeding the GCWR, though? If so, your transmission might suffer as a result and we do have to be careful of ours if encountering long 6% grades. Best to limit speed in these instances to 25mph in low gear with the 4 way blinkers on, as this will up the rating to a 25% overload.
  • Most people on here will tell you No but I would do it and not worry about it. If 200 lbs over would cause the hitch to fail then I would be worried at a few lbs under.
    I would worry more about the towbar. I use one rated at 10,000 lb.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,103 PostsLatest Activity: Jan 21, 2025
