tompla's avatar
tompla
towing Prius with tow dolly
I have a 2009 Toyota Prius and would like to tow it behind my MH using a tow dolly. Does anyone have any experience towing a Prius this way or have you seen it done? I know it cannot be towed all 4 wheels down.
  • My 2009 Prius is a front wheel drive vehicle. I have been told a Prius should not be towed even with the front wheels on a dolly because the hybrid battery will continue to charge and could create an over charge which would harm the battery. I then asked a certified hybrid car technician from Toyota if I could simply disconnect the hybrid battery. I found it to be fairly simple. He said, you should be able to dolly tow the car without disconnecting the battery as the rear wheels have nothing to do with charging the battery.
  • Ivylog's avatar
    Ivylog
    Yes, not on a dolly but only the back tires on the ground.
  • I have a '17 Toyota Camry Hybrid that I have towed many miles on a tow dolly-no problems. Only issue I ever had was using a set of magnetic tail lights and put the wire across the hood. There's now a set of scuff marks where the wires blew back and forth. :S:M
  • Check the owners manual, that's the best source of information for dinghy towing your Prius.
    It should not be a problem towing a FWD vehicle on a tow dolly.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,111 PostsLatest Activity: Feb 18, 2025
