- 12thgenusaExplorerPretty near harmless when empty.
- coolmom42Explorer II
KD4UPL wrote:
Are we missing something? Why do you want to transport it empty?
I assume to take it somewhere to get it filled. - KD4UPLExplorerAre we missing something? Why do you want to transport it empty?
- eubankExplorerYou should take the same precautions that your RV is already outfitted to handle:
1. Transport the cylinder upright (whatever that may be for your particular cylinder).
2. The transport means or compartment should be open to the bottom or at least fully at the side.
Lynn - ScottGNomad
Dakota98 wrote:
Vet Man wrote:
They fit well inside plastic milk crate, if it is a 20lb
x - 2
X3.
As will a 30# tank. - trailerbikecampExplorerLike coolmom said. A single empty cylinder isn't big deal I terms of volume. TDG regulations allow for volumes for personal use. A single cylinder is well below any requirement for TDG transport.
For your own protection, it is best to secure the cylinder in an open area (in case of venting). - DrewEExplorer IIFor the 20 pound bottles (and others of like diameter), you can get plastic carrier trays at places like Walmart that they fit in, with loops to attach bungees or ropes. That's one convenient way to keep them from rolling or rattling around.
You don't want to open the tank to vent every last bit of propane out unless you want to also vacuum purge the air you allow in doing so every time you refill it. - coolmom42Explorer IIDOT regulations apply only to commercial carriers/shippers. Otherwise you would never be able to travel with one on an RV, without being certified as a Hazmat carrier. Personal use is strictly up to your common sense.
Just secure it so it doesn't roll around.
BTW the 20/30 lb round things are technically "cylinders". Other shapes such as those built under motorhomes are "tanks." The only way to guarantee they are free of propane is to remove the valves. Don't think about flushing one with compressed air, a risky combo with a flammable.
I'm a hazmat shipping instructor, know way more about this stuff than I ever really expected to. - Jayco254ExplorerWith the price of propane I never empty one. But I have never given the possibility of regulations against it a thought, maybe I should.
- bandit86ExplorerWhy transport empty, are there some sort of regs or rules?
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,106 PostsLatest Activity: Jan 25, 2025
