stargate3805jc's avatar
May 21, 2014
Travel trailer Tires
Good Year Marathon 225/75R15 Tires
Does anyone have an answer to the question as to how good Goodyear Marathon 225/75R15 tires are to put on my 2006 Dutchman Colorado 26 FB Travel trailer. It's got Duro Radial DS 2100 load Range D ST 225/73R15 tires on it now. I bought the trailer in Sept. of 2010 so the tires have got to be in the 6 to 8 year level where people say tires should be replaced even with lots of tread left and tires have no crack's or blemish's on the side walls. I know I need to look at the DOT number also to know how old the tires are. Thank's for any help you all can be on this matter!
  • Suggest:
    Post your question on the *Travel Trailer* forum (here).
    You can't "double post" so either ask the Mod to move your question,
    or simply re-word it there.
    Try a search on the TT forum. Use keywords like "Goodyear Marathon" (or any brand), "tires", etc.
    Check the box underneath to limit your search to TTs.
    Lots of GY Marathon "thoughts" here by TT owners
    The tire threads here are eventually either closed - or die a natural death. The Thread above ran from 11-06 to 5-11.
    Then went to a poll - and other similar threads.
  • Got almost 8 years out of a set of Marathons. When removed 2 were shot and 2 were still good enough to put on utility trailer. Maintain pressure and keep them covered and off ground when not on road should give good service.
  • wandering1 wrote:
    JIMNLIN wrote:
    If the Duro's, which has a terrible rep with trailer owners (not just RVs) has lasted you for 6-8 years with no issues then the Marathons should work well for you. The Marathons are one of the oldest, if not the oldest, trailer tires on the market.
    ST (trailer tires) should be replaced after 3-5 years so with your tires at 6-8 years your living right.
    If the duros have lasted you for 6-8 years with no issues then get duros.
    My Duros went a grand total of 18 months before self destructing back to base compounds. There are much better available
  • My Duro 2100 radials performed flawlessly for 4 years and 9000 miles through 28 states. I only changed them out because I wanted a higher load rating.
  • If the Duro's, which has a terrible rep with trailer owners (not just RVs) has lasted you for 6-8 years with no issues then the Marathons should work well for you. The Marathons are one of the oldest, if not the oldest, trailer tires on the market.
  • There are many of us that feel Maxxis M8008 radials are the best ST tires available currently. There are many people who feel all ST trailer tires are junk but in the right application they can perform adequately. How much does the trailer weigh ready to roll?
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,130 PostsLatest Activity: Apr 30, 2025
