MartyW
Apr 25, 2014Explorer
On tongue weight, please help me understand this.
I know the tongue weight has to be added to vehicle weight and my owners manual states this. Then it says that, when using a full weight distributing hitch, the tongue weight should be 12% of the loaded trailer weight. So, if I use our 8k lbs max as a fully loaded target, then our tongue weight comes to 960 lbs max. Now, if we change gears in our 3/4 ton 7.4L burb, same chassis, then max tow weight is 10k lbs and max tongue weight goes to 1200 per owners manual. What I don't quite understand is how tongue weight could be 240 lbs different for the same chassis/engine/suspension when pulling with the same weight distributing hitch. Thanks for opening my eyes on this...
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,106 PostsLatest Activity: Jan 26, 2025
