- downtheroadExplorerLeave it there. You can do more harm by trying to remove it.
A sap free, sparkling white roof is not a requirement for having a good time while RVing.
Do you remove tree sap from your house's roof? - tj548ExplorerI agree with leaving it alone. It will eventually dry up and probably just crack and blow away. Chemicals or tools to remove will just damage the roof.
- Clay_LExplorerSap from many trees can be removed by blotting it with isopropyl alcohol and then washing the residue off with a mild detergent and water.
I would be surprised if alcohol would damage the roof but you probably ought to check. - DakzukiExplorer
I would never use a solvent on a rubber roof unless the manufacturer says it's OK. As far as the sap, I'd leave it. The less messing around with a rubber roof the better. - ksg5000ExplorerI wash my roof once a year in the spring --- when sap gets dry enough it comes off without use of any chemicals. Over the years I view the primary reason for "roof washing" is to examine potential problem areas on the roof rather than getting the roof sparkling clean.
- Garry_GayleExplorerI wash my roof with mild soap and water then treat it with 303 protectant twice a year, hopefully the UV protectant will make the roof and caulking along with the vent covers last longer, use it on the slide seals also.
- deleted-2ExplorerIn agreement with leaving the tree sap there.
Rubber roofs are tough and last at least 15-20 years with minimum care.
I spray our roof down monthly with water, wipe down with a large towel or mop then spray off and leave to dry.
Nothing else needed for a roof in good condition.
Be sure to keep the gutters and drip caps clean also. - camperpaulExplorerOdds are it is not really tree sap; it's aphid poop (aka 'honey dew').
- FizzExplorerI do it once a year.
Hose off the heavy grime then use a long handle bristle brush to give it a good scrub.
Don't over do it or worry about getting every stain. - Sfla2ExplorerYou won;t belive this but just put a ice cube on it & it will come right off did it to mine was amazed
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
