Troubleshooting tank odour
Byrogie
Odour is only present in basement of 5th wheel. Not sure if black or gray, not terribly offensive so thinking gray. Can see top of tanks. Connections seem secure. No liquid anywhere.
Gray: Two incoming pipes, one from bathroom and one from washer (not installed and has a waterless trap)
No vent stack directly from tank, shared with drain from sinks with AAV between. Shower drains directly to tank.
Trailer in operation 4 years without this issue.
Vent stacks have not slipped.
question: should I get an odour on roof constantly or only when in use?
Iโ€™m by myself so canโ€™t check black vent, but I smell nothing on roof when sinks and shower running.
Any other suggestions welcome.
1 REPLY 1
opnspaces
Navigator II
Navigator II
Pour a gallon of Pine Sol in the gray tank and see which tank is leaking odor.
Is the AAV one of the cheap $11 jobs? If so unscrew and replace it.
Vent
