SC_camper
Oct 08, 2016Explorer
Underbelly repair material question
Im working on repairs after our tire blow out last week. I've got the water leaks and electrical taken care of. I've straightened out brackets the best I can. I'm ready to install new insulation to the damaged area and close it back up. The Darco membrane was shredded from the rear of the inner fender bracket to the rear steps. I have wood floor joist running from front to back at the frame and outer wall. I can fasten new membrane at the wood joist, overlapping the old membrane, and seal with Flex Mend or similar. What is the best way to fasten and seal the new membrane across the hollow chamber between the wood joist? There is not enough old membrane left in those areas to overlap and nothing to fasten solidly. Will Flex mend tape adhere to the metal bracket? Would it be advisable to cover the newly installed membrane with coroplast for added protection from debris and moisture? Thanks for any guidance.
