Lynnmor
Oct 30, 2017Explorer
fj12ryder wrote:Lynnmor wrote:How did you get around the issue? Or was there even an issue since there was plenty of room for the water to expand?
I would caution those that pour anti-freeze in the fresh water tank if they don't know how much plain water is in the tank that the pump cannot pick up. In my case. the tank sagging between supports and the pump pick up port being well above the tank bottom, there was gallons of water remaining. With the dilution, wasted anti-freeze and considerable flushing in the Spring, it is a poor way to winterize.
I added more support under the tank and moved the pump pickup to the drain hose. If one knows that the tank is perfectly flat and level in both planes, and the pump will pull nearly all the anti-freeze from the tank, then I would accept this method. I send the anti-freeze in thru city water port.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Mar 04, 2025
