- Old-BiscuitExplorer IIIAre you hooked up to 'city water' ?
City water connection has an internal check valve....they will chatter when they are failing or have minerals built up on them. - fla-gypsyExplorer
X 2, this is the answer. Mine does it too but has not failed yet. - Homer1ExplorerShut off your outside supply, then try the same thing using only your onboard water tsnk. If you still have the noise---check your hot water tank CHECK VALVE.
- TS21ssoExplorerJust this past weekend, we had a similar problem. Vibration and noise when city water turned on more that a quarter turn. Didn't solve the problem until I removed the brass water regulator. No problem rest of weekend with absence of regulator.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
