salem's avatar
salem
Water coming into toilet
I have a Thetford toilet with the flusher on the side you pull by hand. The water that flows into the bowl doesn't seem to flow as strong as it used to. Any ideas why? Could it be just gunk built up inside the hose?
  • I may have enough room to work back there. Thanks.
  • Toilet only has to be pulled if too close to the wall. The flush valve slides out and may hit the wall before it travels far enough to remove from the slots.
  • Thanks to both of you. Obviously, I was hoping to avoid pulling the toilet. :) Thanks for the pictures.
  • That's what mine did, pulled it and with a tooth pick busted up the hard water deposit and worked like new, easy fix, except you might have to pull the toilet to remove.
  • That sounds like an Aqua Magic V hand flush toilet.
    There is a water module on backside that can get clogged from debris/scaling. No screen so gunk collects in water module
    There is also a flush tube/nozzle assembly that goes from water module to toilet bowl......nozzle can get clogged also.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 21, 2026
