Puddles's avatar
Puddles
Water Heater Problems
Heater started sounding like a jet when propane came on... flame was way up in the tube. Suggestion was that the regulator was bad, flame shouldn't be up in the tube. Replaced regulator and problem went away for 2 weeks... next time used the heater, back to jet sound and flame up in the tube.. Installed another new propane regulator... Same problem the first time heater came on??? Any suggestions appr.
  • Wellllll... found the problem, big end of the burner tube was rusted off. Supposed to be a baffle near the end where the flame comes out. New tube fixed the problem.
  • If you think the regulator is bad, start by making a manometer and checking it. I bet there is a bit on youtube for this.
    Matt
  • I don't think I can help but I do have some suggestions. Post this in the Tech section. Include as many relevant details as possible, including make of unit, original regulator and replacement.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,110 PostsLatest Activity: Feb 16, 2025
