Still trying to get the valve settings right. There are no instructions on mine as there are on the 13s. My valves read: FW IN @ 12 o'clock & pump @ 3 o'clock then FW OUT @12 o'clock & pump @ 3 o'cl...
SCH is probably right about the low point drains. Get them shut. They are probably inside.
You are not very clear about the others, but it sounds like you have two each two position valves so there is not an "ON" and "OFF". One valve selects to fill your tank from the city connection or the tank to the pump suction (in), and the other selects your system source as from the pump or the city water connection.
Matt
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,110 PostsLatest Activity: May 20, 2013
