BlunderLust's avatar
BlunderLust
Weight distribution / anti-sway hitch recommendations
I've found some great travel trailer models thanks to the most helpful folks here. To tow the trailer I think I'll need weight distribution and anti-sway hitch add-ons. A trailer I'm considering is the Nash 17K with a weight of 4400 lbs and NCC of 2600 lbs. My truck is a 2015 Ford F150 SuperCab 3.5L EcoBoost 4x2 145" Wb 3.55 axle ratio. Ford states this version of the F150 has a max trailer weight of 12,100 pounds so I should be OK with the weight even with a maxed out NCC and Ford has overstated the actual tow capacity.
For such a truck/trailer combination is there a specific brand/model of weight distribution / anti-sway hitch which is recommended? Thanks!
