Turtle_n_Peeps
Oct 12, 2016Explorer
Thanks Ben.
GMW sounds like you did a great job of setting up your rig! You know all your weights and set your rig up to them.
I get a lot of people don't have access to scales like I do and for them just transferring a bit of the weight is usually good enough. For those of you that do have access to scales go the extra mile and dial in your setup like GMW did.
If you do you will be rewarded with a superior handling rig.
While I'm at it. Set the front end of your trailer 1 or 2" low in the front. It will help with panic braking a bunch by keeping things in line.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,101 PostsLatest Activity: Jan 14, 2025
