- FIRE_UPExplorer
campingman55 wrote:
Ok for the people that tow 4 down and there toad has a lube pump what do u do when u stop for over night about the lube pump turn it off or what do u do
I've never had a lube pump and, most likely never will but, I suspect that if yours is wired properly to the coaches ignition, yours too, just like the other posters, should shut down automatically when the coaches ignition is shut down. At least that seems to be the logical way it should be wired.
Scott - Dutch_12078Explorer IIOur lube pump shuts off when the coach engine is shut off. The dash mounted controller handles all that.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Mar 04, 2025
