- covered_wagonExplorer
Eric&Lisa wrote:
SoundGuy wrote:
Eric&Lisa wrote:
Oh, and water the battery every season. Just do it.
Read what the OP actually posted and you'll see he's looking for Trojan T-105 AGM batts - NO watering an AGM. :R
Good catch. Here is a re-write to ensure no one else is confused:
"Oh, and perform regular maintenance on the battery as required by the battery type. My first Trojan wet cell battery made it a full decade before I decided to proactively replace it. Absorbed Glass Mat batteries do not require watering, but do have different maintenance requirements for long life. I encourage you to consider the RV battery as an investment and take care of it accordingly, especially when buying a premium brand like Trojan."
Way I understand, is Eric and Lisa are only trying to share why a wet cell battery is better than AGM. Simply that you can maintain it. That is good reason for try helping the OP and I respect their willingness to care and share. - JaxDadExplorer III
Add a tablespoon of mineral oil to each cell of a normal battery and you won’t have to add water to it either. - allen8106ExplorerBuy Crown.
- westendExplorer
2oldman wrote:
Or, more likely, an untrained cart jockey overfills the batteries. I caught two of them filling batteries with a garden hose just feet from the Clubhouse Locker Room entrance. I never did inspect the carpet inside the Clubhouse but I bet it wore pretty fast after tracking acid on it. It was just one of a hnadful of times that I lost my cool at that Golf Course.
Perhaps the OP is asking for suggestions on getting AGM batteries, not wet ones.
GCs should start using AGMs. I've seen some pretty horrific looking batteries, wiring and corroded compartments on acid carts. They bounce around a lot and perhaps get overcharged. - theoldwizard1Explorer II
JoeH wrote:
I recently bought 8 Duracell AGM CG-2's for replacement house batteries at Sam's Club.
Not available at my club ! No mention of shipping them in. Bummer !! - Eric_LisaExplorer II
"Oh, and perform regular maintenance on the battery as required by the battery type. My first Trojan wet cell battery made it a full decade before I decided to proactively replace it. Absorbed Glass Mat batteries do not require watering, but do have different maintenance requirements for long life. I encourage you to consider the RV battery as an investment and take care of it accordingly, especially when buying a premium brand like Trojan." - covered_wagonExplorerI'm glad AGM type batteries came on the market. It helps the wet cell prices from the lower demand on them.
- 2oldmanExplorer IIPerhaps the OP is asking for suggestions on getting AGM batteries, not wet ones.
GCs should start using AGMs. I've seen some pretty horrific looking batteries, wiring and corroded compartments on acid carts. They bounce around a lot and perhaps get overcharged. - JoeHExplorer IIII recently bought 8 Duracell AGM CG-2's for replacement house batteries at Sam's Club. They are the same size as T-105's
They are made in the USA by East Penn. They were under $170 each , which if I remember correctly is over $100 less than the Trojan .
Just another option to consider - jplante4Explorer IIIf you aren't stuck on getting Trojans, you can get Interstate CG2s just about anywhere.
I've seen T105s advertised on hand made signs in Florida for $87. I wouldn't touch that.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,152 PostsLatest Activity: Aug 01, 2025
