Oct 05, 2017Explorer II
The F250 weighs over 2000lbs more than an F150. I get 20.5 MPG running empty on the highway in my EB. If I dropped 1 ton of payload in my bed I would get probably about 12 MPG. Hitch a trailer to it and it would only get worse.
The turbos load up at about 1800 RPM and I can see it happening on the instantaneous fuel usage indicator. The turbos on a 3.5EB F250 would always be loaded, 100% duty cycle and would suck the gas. Forget 4WD. That would only make it worse.
An F250 with a 3.5EB would get horrible gas mileage empty.
That would remove the incentive of owning the truck.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
