Dakota98
Sep 22, 2014Explorer
Winterize questions
Once again, the time to put her to bed is here.
Last year I winterized the TT myself for the first time. I decided to use air & everything worked great. Simple, & less pink stuff was needed. I used the anti-freeze in the P traps & a little in each holding tank only.
Even though, things were fine this last spring when I started to use my TT once again, I have a few concerns.
My water heater has a By-pass & I did open those valves also last year, but it is difficult to get to. Do I really need to concern myself with the by-pass at all ? I do drain the water tank as the first step in this process of using air.
Also, By connecting the air to the city water connection, how does this affect the 12 volt water pump & does this method purge the pump of any residual water? Or is there something else I need to do for the pump itself ?
And last question, I've seen posts for "air pressure" setting anywhere from 20psi to 65psi. My 12 volt pump operates at 45psi & I would think that an air pressure setting below that would be safe. I used 25psi last year. What's your opinion ?
Here's a pic of my set-up connecting to the city water.
