luberhill's avatar
luberhill
Winterize questions
Ok blow out method or antifreeze ?
And if I do the antifreeze do I leave the bypass valve in the bypass position until I put the rv back in service or open it after I’m done adding the antifreeze
Also I know how to drain the tank but when done it says replace the plug and close the pressure valve , does draining it get ALL the water out ??
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 24, 2026
