seekingsummits
Oct 27, 2021Explorer
Winterizing Issue
Ive had this TT for 5 yrs and have never had any issues winterizing. Usually i use 2-3 gal of antifreeze and im good to go. This time I bypassed the water heater like normal and diverted the pump toward the hose for the antifreeze. No issues with suction, but after 4 gal being sucked up I was really scratching my head. Normally by 1/2gal the lines are pressurized and the pump turns off. This time I put 4 full gal in and it was still going. Only thing i could figure was to swap the valve on the outside from “city water” to “fresh tank”. Once i did that everything went fine. Im assuming i was sucking antifreeze into the FW tank, I guess my question is do you always need to have the valve to fresh water tank vs city water? I find it hard to believe that the last 4 yrs i always got lucky and the valve was already switched to fresh water, esp since Im almost always on fulll hookups. Just seemed odd this yr
