ivbinconned
Aug 20, 2019Explorer II
Winterizing kids Cruiser. Hot water tank question
Our old Skamper and our newer Cedar both have 3 valves at the hot water tank. The tank is isolated by closing the in line and the out line. The pipe joining the two lines has a valve that is then opened for winterizing.
I didn’t have to tell you all this because you already knew it.
The kids Cruiser has a valve on the in side at the bottom...but no valve at the top out line??
There is a valve on the pipe between the two lines as I would expect but if it is open wouldn’t the tank then fill from the top.?
I’m confused.
I’m confused.
