Whiskey_River
Oct 19, 2021Explorer
Winterizing Residential Fridge
I have the Samsung RF18 Fridge with Ice Maker. After checking various google posts & forums on how to winterize it, there appears to be no easy way. Everything from accessing the back of the fridge (its in a slide) remove the water line, removing the actual ice making thingy, make a jumper wire for the water solenoid, and other various scenario's.
I feel like I'm trying to "redesign the guidance system" on a cruise missile.
Has anyone done this? After pumping the pink antifreeze thru the water lines & opening & closing all the various spigot's just leave the pump on with the hose in the gallon of pink antifreeze and turn on the fridge ice maker. I know the antifreeze will not freeze in the ice maker. Will this work & will the ice maker dump the pink antifreeze so you know it has pumped through the ice maker? Anyone have any actual advice of what I can expect? Thanks....
Or should I just head for Florida....
