Bumpyroad
Oct 28, 2019Explorer
Kansas couple wrote:
Yes, did the water heater bypass and flushed the pink stuff through the toilet.
This was not my first time winterizing the camper. Rather it was the first time I used the pump kit. Previous years I put the antifreeze into the fresh water tank. Not complicated but it sure uses much more antifreeze than the 2 or so gallons I used this time!
so you previously got antifreeze thru OK from the FW Tank but couldn't from the bottle/kit? and you did everything else the same? you did put the "T" valve before pump? doesn't compute??????
bumpy
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,110 PostsLatest Activity: May 20, 2013
